Mains Sockets?
I'm looking for "audio grade" alternatives for this socket:
http://www.audio-cube.nl/furutech/FI-E30.htm
Any ideas, hints or tips?
"Audio grade" version of a power connector? What are you trying to do? If you want a connector for high power speakers, look into the SPEAKON connector. it is made for the job and is a standard in professional speaker systems.
Speakons are made by Neutrik, but other brands make compatible mating connectors for it.
Why not use what here in the UK is called a 'fused spur box'?
It's a fitting with a fuse and captive cord fitting, and avoids any possible plug / socket resistance, etc. To isolate the appliance, you can remove the fuse (it's usually in a quick-release holder) or switched versions are available.
Certainly. generically we tend to call them Hubbell connectors after a well known brand. At least in my industry we do. The Hubbells tend to have a push in and twist insertion that is very secure.
Google Hubbell Connectors for a start.
But regardless of brand, the white plug in the photo is just the most basic household variety plug. We call those Edison plugs. Usually rated to like 15 amps. There are electrical standards for connectors with far higher ratings. We use them on large power tools, things like electric cook stoves, clothes dryers, etc.
