Magnepan .7
I don't think I've seen a 0.7 crossover schematic. Magnepan no longer makes schematics available to customers, so you'd have to inspect an actual speaker and draw it out.
I suspect there's just two/three components. And it's a series crossover.
Dave.
Sure. there are 3 caps - 2 appear to be poly (10uf each) and the 3rd is 75uf. Then a 1 ohm 10w wire wound resistor. See attached
Reactions: Wieslaw Lipowski
Aside from the increasingly widespread belief that passive XOs make little sense today, going active (which almost always now means DSP), you can run these find panels with a wider passband using sharper slopes, not to mention the other improvements.
B.
B.
Sharper slopes just means a more abrupt change in the polar response of the speakers. Not necessarily a good thing.
These speakers are not bothered by shallow slopes anyway.....relative to conventional speakers.
Dave.
Reactions: DIYspaceW
