MAGNAT All-Ribbon 2 Crossover - Upgrade Required?
I decided to use the LOCK-DOWN time to peep inside our beloved MAGNAT All-Ribbon 2 speakers - circa 1990, Germany - and check-out the crossover.
(No sound issues - just curious...)
So here's a quick pic.
To these eyes, this appears to be a pretty respectable bunch of components.
Looks like a decent polypropylene cap for the tweeter.
(Please correct me if I'm wrong...)
Air-gap inductor. Nice.
And huge copper ground-planes on the reverse of the crossover.
At 30-years old, one would suspect that the (bipolar) electrolytic caps need to be replaced - assume these are for the woofer - but a bit hard finding suitable alternatives that are not electrolytic.
I know sand-cast resistors have a few detractors, but I have always figured that if DC is not present - as it absolutely should not be - it shouldn't make a difference.
Any thoughts from the panel as to some quick wins here?
I have some nice, low-value MOJO polypropylene caps lying around for bypass duties, if anyone can see the need.
Or should I leave as is?
(No. Sadly, my new ESR tester has not yet arrived...)
I think Sonce has it in a nutshell.
If you have been happy all these years, the 27uf Bipolar electrolytic is the only sensible candidate for a replacement. I like the Mundorf ones. Not expensive, and not too large. Check the basic dimension to ensure it will fit before ordering or hitting the buy now button.
Have fun.
Total Crossover Re-design... Nope.
So you have time...
measure raw drivers dual channel on the box 0-180deg
take impedance curves
throw all data to vituixcad
start simulating old crossover.
I´ll bet you can make it better than original
Thanks for the vote of confidence, MANNINEN.
I simply don't have access to the equipment, to make the types of measurements required.
That said, I believe the Germans made a great job of the original, as these speakers sound sensational.
Have fun.
Thanks SONCE and RAYMONDJ.
I had pretty much come to the same conclusion on the bipolar cap - but 27uF values are not easy to find. MUNDORF appears to do a 22uF before jumping to a 33uF, so I may have to do a bit of "combining".
Let's see what I find...
