Hi Wolf!
Nice pics. 🙂
I saw about 2 dozen mid/woofer drivers while at Magico. They all had the Seas rubber boot around the magnet. That's not to say other brands weren't also used. Like I said, I can only go by how little I saw. 🙂
Magico claims to use a 10um diamond coating on the SS Be domes, so not exactly off-the-shelf.
I'm also not hugely invested in what Magico uses or not, by the way. While I envy their aluminum fabrication, and cash flow I was not moved. I wish them and their fans lots of success.
Best,
Erik
Nice pics. 🙂
Best,
Erik
Funny! 🙂 They are pretty nervous about that. I asked and they assured me that the drivers were no more or less rugged than your average driver, but they certainly do not like to clean off finger prints. 🙂
Erik
Erik
Another option can be the use of Eton drivers.
They also have a honeycomb membrane and what i have heard so far, they are really good and of course $$$
https://www.intertechnik.de/Shop/Loudspeaker-kits/Loudspeaker-kits-with-Eton/_BSMIDU2_1768,en,2668,144991
I remember reading, they where made from the same special material as helicopter rotor's + a grown man could stand on them easily. Maybe earlier model 🙂. -edit- Found part of the quote: http://www.theabsolutesound.com/articles/the-technology-behind-the-q7/
Magico Chief Technical Officer Yair Tammam says:
"This cone is woven from a carbon-nanotube material originally designed for helicopter blades where light weight and stiffness are absolute requirements."
Stereophile Alon Wolf: To Move Out of the Way Page 2
Read more at http://www.stereophile.com/content/alon-wolf-move-out-way-page-2#cmSwzGSV7pKF53hX.99
"You can put this cone upside down and stand on it and nothing will happen to it," says Wolf."
So good to know that you could do that, stand on the cone without damaging it. How about suspension, upper and lower? 😀
The carbon nanotube material is graphene, but he doesn't divulge if it's a graphene powder/resin or graphene sheet( used between layers of carbon fiber)
Shrug..... I'm pretty sure the Seas motors had the carbon fiber cones. Maybe these were all for the S1 Mk II they were about to introduce??
Someone buy a pair and disassemble it so we can know for sure! 😀 😀
Like I say, not too worried either way, I won't be replicating what I heard there anytime soon. 🙂
It seems the biggest difficulty is getting the Mid Woofer and the Woofer.
On Ebay I found a couple of finished Magico drivers publications.
The Realistic option seems to me is to try to make a variant of the Magico Mini Originals.
Subefotos
Of these to the Teeter is still available, even so, I think the best option is to use test: Scanspeak Illuminator D3004 / 6640-00 1 "Tweeter Beryllium Dome.
The Woofer is very difficult to get, the Volent Paragon VL-2, use the same Driver. Beyond that you have to expect a stroke of luck to get them, so I have to find the best alternative. For this I am studying the characteristics of different Woofers and apparently there is on the market a Titanium woofer like the original, the ones that are closest to it seems to me are those of aluminum sandwich.
These are the ones that I have in mind:
SEAS Prestige L22RN4X / P (H1208)
8 "Aluminum Cone Woofer
125W
8 Ohm
86 db
20-1000 hz
Görlich-Podszus TT 170 rubber seam
Aluminum sandwich bass-midrange cone
Frequenz ab ca. 23 Hz
Impedance 8 Ohm
Max. Frequency 3 kHz
Kennschalldruck 1W / 1m 87 dB
SEAS Excel W26FX-001 (E0026)
10 "Aluminum Alloy Cone Woofer
8 Ohm
20-1000 hz
150 W
SEAS Prestige L26RFX / P (H1209)
10 "Aluminum Cone Woofer
125W
8 Ohm
88 db
20-1000 hz
Morel TSCM634 6 "
Titanium Supreme Carbon-Fiber Midrange
49 Hz to 8,000 Hz
Nominal Impedance Z 4Ω
Audax HM210C0
8 "Carbon Fiber Woofer
8 Ohm
70w
Aurum Cantus AC165 / 50C2C
6-1 / 2 "midwoofer
• Sandwich cone of non-woven carbon fiber
Nominal Diameter 6-1 / 2 "
Power Handling (RMS) 150 Watts
Power Handling (max) 225 Watts
Impedance8 ohms
Frequency Response 37 to 4,000 Hz
Sensitivity90 dB 1W / 1m.
Audiotechnology
C-Quenze 15H520613SD
Medium-severe
Resonance Frequency - fs: 48 Hz
Equivalent volume - Vas: 16 liter
Nominal impedance- Zn 8 OhmSonus
Faber Stradivari Drivers
Scanspeak Illuminator 18WU / 4747T-00,
7 "Aluminum Cone Woofer
4 ohm
32hz
80 W
Are there any other woofer that you have to consider?
Subefotos
125W
8 Ohm
86 db
20-1000 hz
Impedance 8 Ohm
8 Ohm
20-1000 hz
150 W
125W
8 Ohm
88 db
20-1000 hz
Morel TSCM634 6 "
49 Hz to 8,000 Hz
Audax HM210C0
8 Ohm
70w
6-1 / 2 "midwoofer
Impedance8 ohms
Audiotechnology
Medium-severe
4 ohm
32hz
80 W
The SEAS based bass drivers for Magico.
They did use XLS/XXLS drivers at one point, but they've clearly had a custom unit made from SEAS too. This looks like their L26ROY line.
Looking at how the Görlich-Podszus TT 170 measures I wouldn't bother going with it. A huge whacking resonance issue in the 1-2kHz region and poor non-linear distortion. What exactly are you paying for here again?
Good find! Looks like a similar Matt black finish used on the discovery 10". The woven cap with the Matt finish is a bit odd IMO
I'm Looking for a reasonable similar curve than ATD 18W4004-AGTi
Beautifully flat between 100 and 700 Hz
I think we should also keep in mind that the Woofer should have most of these features:
30Hz -? Hz CrossOver Cut
Sensitivity: 91.5 dB
Nominal impedance: 4 Ohm
Subefotos
183/5000
Mostrando traducción para para sacar provecho al rango de twitter, a que frecuencia debo hacer el corte? Estoy pensando a unos 700 Hz (se que eso va a depender del Woofer que se pueda conseguir)
En su lugar, traducir del para sacar probecho al rango del tweeter, a que frecuencia debo hacer el corte? Estoy pensando a unos 700 Hz (se que eso va a depender del Woofer que se pueda conseguir)
To take advantage of the range of twitter, how often should I make the cut?
I'm thinking about 700 Hz
(I know that will depend on the Woofer that can be obtained)
Subefotos
183/5000
The curve of the Görlich-Podszus TT 170 looks quite like the Original, but there are 3 things I do not like about this driver:
1) It is 8 Ohm (the original Tweeter and woofer are 4 Ohm)
2) The sensitivity is much lower than the Original and the Tweeter
3) I did not find reviews of this driver
XLS/
https://www.madisoundspeakerstore.com/approx-10-subwoofers/peerless-830452-10-xls-subwoofer/
XXLS drivers (Take a Look at datashet)
http://audio-hi.fi/download/pdf/Peerless_XXLS10_P830951_subwoofer.pdf
Seas L26ROY 10" Subwoofer
https://www.madisoundspeakerstore.com/approx-10-subwoofers/seas-l26roy-10-subwoofer-d1001-04-4-ohm/
Thanks 5th! I feel validated now. 🙂 I only make up about 60% of the stuff I post. 🙂
Sad about the Seas Roy drivers though. I was eying them for a future sub project.
-E
-E
The ATD driver is not completly unobtanium. But sort of. You have to buy 50 pcs: Chassis ATD-Serie \| Expolinear
Cloning without the same mid is senseless IMHO. I would not worry a bit about the 10 inch woofer beeing Wavecor, Seas or Scan Speak. All great performers in the "alu cone" piston movement department. Just buy the one with the best specs. But at least the mid/ tweeter section should be close to the original. The crux of the Magico's seems extreme engineering without taking shortcuts. Cloning will neither be easy or cheap. Just like the original. I don't get cloners at all, so will refrain from further commentary.
-E
Interesting!! I saw that photo but didn't click on it. It just appeared to be the XXLS/Discovery like they always used before. Now that 5th posted it- I see the frame and the magnet boot do closely resemble that of the L26ROY, but the cone still looks like that of the XXLS.
Erik- what do you mean 'sad about the Roy drivers though'? The price?
Later,
Wolf
- Magico Drivers
