Mackie MA1400 thermal stay on
Temperature light stay on even though the Heat sink is cold as ice.
I have a M1400 amplifier for some reason the temperature light stay on. I checked all my pre amp transistor and the output transistor all seem to measure fine. Also the temperature IC U1 (LM35DZ) it's okay. I have changed the LM339 IC as well . Still no changes. Any suggestions.
the unit stay on but no sound, I have check all my voltages. I have the +-16V and also my +-80V output transistor is stable.
what do mean "If working, check the supply lines to the sense section." because sense section I have changed the LM339 and also check for any open circuit resistors.
