Macintosh SPDIF
Dear All,
I have a MacBook pro 13, that is supposed to have a spdif output 24/192. I connected to my Denon 3808, that is supposed to have a 24/192 input, but I only managed to play 44.1 khz tracks, or more precisely, the Denon is telling me that the input is 44.1 khz.
As I am not sure of anything in this game, my question is. How to know what is coming out of the MAC ? I was using Songbird to play 24/192 files for the test.
Thanks,
Davide
Go to Finder>Applications>Utilities>Audio MIDI Setup. The issue of sample rate problems has come up when using a USB DAC (see Stereophile review of the Benchmark DAC). Correcting the settings in Audio MIDI setup fixed it. But I'm not familiar with spdif and whether it will apply here. But it's worth a try, anyway.
quicktime has nothing to do with it, audio-midi prefs is the only place you need to set it if using the onboard sound. the optical will only give you 24/96 though. a setting made in audiomidi panel will be reflected in all applications that use it, proprietary or not as long as they are written appropriately
