M-Audio SuperDac
Joined 2002
Tried to reply to the http://www.diyaudio.com/forums/showthread.php?threadid=9616&highlight=superdac tread...but it did not work..?
I have tried some of the "usual" mods to this unit:
1: Tantal-cap 4.7uF
2: OsCon 47uF(had one...)
3: Tantal 10uF
4: DAC analog supply caps 56uF Elna
5: DC-block-caps: Bi-pol 47uF bypassed w. 470nF
6: Op-Amps OPA627 (Bal-out) AD825 (RCA)
7: Extra filter for DAC Analog supply
8: RCA-connectors
To come: PSU-upgrade including caps....
Have tested between every change. Steps 1-4 did only give small changes, 5 was a great leap, step 6 was ofcourse even better....
Please tell me where to implement a separate CLOCK..?
Arne K
Norway
Arne K
Norway [/B][/QUOTE]
Use a separate beefy transformer and this has a big improvement.
You should also improve the filter network with all those cheap ceramic and mf resistors.
Joined 2002
New tweaks...:
Having read somewhere on the web-pages at TAG McLaren, they had a upgarde service for some product changing the AK4393 DAC-chip with AK4395, I decided to try the same!
Have also done a little re-routing of the error-detection on the CS8414.
And new analog filter-caps.
So far I'm pleased, but hardly worth the $$ (?).
Arne K
1: Tantal-cap 4.7uF
3: Tantal 10uF
8: RCA-connectors
Could one skip steps 1-5 and just add op-amps?
Wouldn't OPA627's work for the unbalaced too?
Cobra2 said:
Yes!
(Just remember the RCA-out first go thru' the "balanced" op-amps)
Arne K
So does that mean that the AD825 a better choice for the RCA? What would happen if I use OPA627 in both? The reason I ask is that I have alot of OPA627 on hand at the moment. Are there other op-amps that you have tried that sound better for the RCA?
(Sorry, if these seems like silly questions but I am new to DIY.)
