Hi Jason,
I wonder if you there's an ETA on the availability of the lx-mini crossover?
Thanks,
Dennis
Thanks,
Dennis
Very soon, 1-2 weeks (that's programmer's optimism). A conservative estimate might be 2-3. But I really think 1-2. I am usually wrong. Let's see.
Is there any update on this product availability?
It is now available: Analog Crossover Network – diyAudio Store
If you experience any problems in order, please post here.
LED's for Analog Crossover
Are the LED's in the extra parts kit for the Analog Crossover just for cosmetics for the chassis or do they have an operating function? I'm asking because I need to put the kit together the kit on the cheap and can't afford parts kit beyond the basic kit.
ACN for Linkwitz Mini's
Having just completed Nelsons fine product , it sounds great. I like to stream audio and I use a Cambridge Audio CXN that has a very nice DAC. When you use the original MINIDSP crossover the signal is run through two dacs , by replacing the minidsp with an analog crossover[ ACN ]It improved the sound to my ears . Thanks Mr. Pass
If I use the two Hi outputs on one board for XLR, do you not have to have one signal out of phase to have a balanced output? How would you achieve this?
The LX mini is not ment to use balanced, but you can put a balanced line transformer at the output if you like to drive your amps balanced. Or an unbalanced-to-balanced circuit. Or use another solution. One advantage with LX mini is the simplicity and I think it is a pity to add active stages.
Are there any instructions available for wiring 2 of these crossovers for XLR balanced output??
It would be better, and more accurate, to use it single ended, with a SE -> BAL converter at each output.
Use a single op amp in the inverting mode, with two 10k resistors for the feedback (x -1 gain) for the
negative phase, at each filter output, for each channel. The normal filter outputs are the positive phase.
- The diyAudio Store
- LX mini analog crossover
