Luxman tube amp capacitor replacement
Hello,
First of all I would like to apologise for this silly question - its been more than 10 years since I've built an amp myself or touched a soldering iron really. I've forgotten so many things. Please let me know if this is not a place for such question and I will delete this post if thats the case.
I have this tube Luxman amp from the 80s that I am planning to recap.
The problem is that I cannot find replacement units for these.
Searching by the code on top yields zero results. They all have 4 pins which I believe I never dealt with. Maybe you guys could lead me on a path?
Check out this company...
If there is room in the chassis, I would leave the originals in place and hide modern replacements there. You can make a little board, or mount a tag strip to hold the replacements. Modern electrolytic capacitors are compact, and concealing replacements in the chassis is quite possible.
One of them is visibly bulging on top
And that's why you want to change them?
I'll give you a little lesson since I've retired from 40+ years in the home audio service business...
The "domed top" of the shrink wrap is a normal thing - not a defect of the capacitor.
It's the result of normal heat from the chassis components causing tightening of the wrap, which then deforms and domes the disk.
Since those are first class Chemi-cons, I'd leave them alone.
