Lumley M120 Monoblocks - Need Manual, schematic or anything !!!
Make sure your valves are in good order.. Get their output voltages of the power valves checked .. Only do this if you know what you are doing as it involves the amp being turned on and specific pins being tested. Might be an idea to make sure your power transformer is showing around 2 ohms on the winding.. Again only to be done by electrically trained engineer. Do not touch otherwise as lethal voltages are all over the circuit.
urgently need some details on this amp.
anyone have anything they can share ?
thanks
I have the m120 manual if you still need it after all this time.. I can make you a copy and send in post or email.?? The amp at the end is one of my current M120's .. I have a pair for sale if interested £3500
Hi, sorry about the late reply.
yes a copy of the manual would be great.
my email is andy-404@hotmail.co.uk, if it's easy to scan or you can post to
andy turner, 17 durban gardens, dagenham. RM10 9XU
I don't suppose you have the circuit schematic anywhere ?
I've kind of pieced it together from other grant/lumley designs
but the actual diagram would be really handy.
I've made a few bias improvements which has made biasing
a whole lot less fraught and more accurate.
let me know if you are interested & I'll send details.
many thanks,
andy
