Sorry if this has been ased before, but after searching the site, I didn't find the exact answer I need, so here's the question:
I have the lighting kit from lumen lab (ballast everything), I wired the ballast to the lamp according to the diagram on the ballast itself, but I did not understand the diagram about wiring the ballast to the outlet.
Can someone provide me a description/diagram how to wire to the outlet from the ballast. There are only 2 wires (brown and blue) from the ballast, but does it matter which one is hot/common? I want to be sure. Thanks.
