LU1014D Power JFET DISCONTINUED
Okay okay - got the message.
Sadly that must be the ultimate end of power JFETs:bawling: , or does anybody else produce some...?
I bought some recently from www.audioprojekte.de, and they still lists them for 3.60€/piece. So I guess one should be quick if they wanna join the Power JFET club.:smash:
I am just really looking forward to getteing time, to make some PassDIY F3/Z9 for my tweeters, and some 100W class AB á lá Yamaha B1 for my woofers.:snail:
And no, don't ask...I've been out of the Lovoltech/Qspeed JFET supply business since last year. Yes, I still have some. No, you can't have any. They're the ones I saved so I could build a thing or two.
You can't build a Yamaha B1 or B2 with the Lovoltech/Qspeeds--they're N-ch only. The Yamahas used a complementary output stage. No, Lovoltech/Qspeed never made a P-ch.
Grey
hey Grey
From the Pass Z8 article:
http://www.6moons.com/industryfeatures/zen8/1.gif
...it seems that the Yamaha B1 only is with N-channels.
Eitherway - I know that there is no P-channel, and one would have to make some changes to use the 'old' Sony and Yamaha Power JFET circuits with Lovoltech.
Among other change bias voltage, cascoding for protecting the LU1014s for excessive drain-source voltage and power dissipation=heat, and maybe more changes.
Here is some good inspiration with the old 2SK82:
http://www.est.hi-ho.ne.jp/jack-morita/sub02/sub02.html
http://www.est.hi-ho.ne.jp/jack-morita/sub06/sub06.html
I know I've got the B-2 schematic, and I think I've got the B-1. I'm pretty sure the B-2 is complementary, but I may have slipped a cog mentally. If the B-1 is quasi, then that's going to be a more appropriate topology.
Cascoding isn't an option, it's a must. If you're going to run any amount of bias at all, you're going to be very limited in terms of voltage swing and/or heat dissipation. The only exceptions would be something like headphones or some of the more efficient full-range drivers out there.
Grey
Grey
I imagine something like a Class AB quasi with +/- 35Volts supply and the speaker would be a 6 ohm (8 inch bass only driven from 80-700Hz, with active crossover)
Say one cascode both the negative and postive LU like NP did in the F3/Zen, leaving some 3-4 volts over the LU1014 - that would take care of the voltage swing- right?
At maximum voltage swing, the average current thorugh the transistor will theoretically 35/6/2= 2,9ampere and power dissipation 4x2.9=11,6 watts.
(edit: i havent even subtracted the voltage lost in the cascode MOSFET)
I am only in the stage of basic thumbruling-achitecture, but does it sound completely nuts?
I could ofcourse also paralell two LU1014s in each leg.
