LTspice problem simulating old amp with single supply
Usually I don't encounter much problems simulating amplifier schematics, except when attempting to simulate (older) amps with a single power-supply.
Problem is that THD figures in most cases do not match the specs provided by the manufacturer (off by a factor 10 sometimes). This also might lead to the conclusion that the specs are wrong, but since I'm not a LTspice specialist, I assume that there is a "bug" in my knowledge of LTspice to simulate these schematics in a proper way.
Frequency response seems ok, BTW.
Currently I am not able to attach a schematic (I'll do so when I have the opportunity) so I'll give you a description of the layout.
The input circuit consists of a single PNP transistor. The (resistor loaded) VAS is build around one NPN. The power-stage uses a complementary driver and two NPN power transistors, also feeding a bootstrap. The LS is connected through a decoupling capacitor.
Anyone suggestions? Please enlighten me 😎
Two things: you didn't specify the timestep for the sim, and LTspice has chosen what it thinks is adequate, but isn't in this case, because it is audio, and you left the waveform compression active: for audio, it has to be turned off by including the directive .options plotwinsize=0.
With these mods, the sim gives more realistic results, maybe leaning a bit too much on the optimistic side this time.
  • Esgigt.asc
    Esgigt.asc
