Since the August update the LTspice started showing this error, does anyone know the solution?
Alberto.
Alberto.
Error in model description in TUBE.LIB file.
Most likely, the sign of line transfer + was lost when setting the parameters of the vacuum tube.
You are right!!
I added a model that looks like it had errors, deleted it and the problem is over.
Thank you!
Alberto.
Thank you!
Alberto.
Joined 2009
