LTP transistor Matching
It looks like the winner is input resistor mismatch.
Left input transistor has a 26.3K resistance to ground.
Right input transistor has a 13K resistance to ground.
Input pair current looks like about 2.25mA each. 2N5401 can be low beta, but let's say it's 100. 22.5uA*13.3K = 300mV.
Quickest fix is to double the size of the feeback resistors, both Rseries and Rshunt. Harder fix is a bias servo.
Hi Russel ,
I changed the feed back resistors to 27k and 680 Ohms , DC offset dropped from 109mV to 70mV. This was a quick check , i will try to get the feedback resistors to 26.3K.
Thanks a ton
