Lt3042 anything better ?
Hello. I need a low current regulator for a dual supply +15 -15v opamp, the lt3042 seems perfect for the task, and the 3094 is for the negative.
But is there a better specs (lower noise and pssr at audio frequencies) than this, in a single chip form factor ?
I know i can parallel chips but i am looking for a single chip solution.
Thank you.
What about the Texas Instruments TPS7A4700?
Using a transformer with 2 independent secondaries will easily give you a "+/-" PSU - with the lowest ripple current (Output Voltage Noise: 4 µVRMS (10 Hz, 100 kHz) that I know.
Regards - Rudi_Ratlos
they are similar. But 3042 /94 is lower noise, and a bit faster.. then, I found it produces less peaking in the transition from regulator output to bypass cap impedance..
The parameter in which the TPS7A could be a bit better (slightly) is the output impedance.
Ciao, George
It all depends on your use case.
LT30xx:
+ lower noise below 100kHz
+ more diy-friendly package available (MSOP)
- only up to 15V/500mA
- higher output impedance
TPS7Axx:
+ lower output impedance so it may work better with load transients
+ up to 34V/1A
- higher noise
All these regulators does need a substantial amount of load current, for performing to datasheet values!!
So don't even dream of piloting only one opamp..
the LT series I have seen to come up, work ok cca above 50mA. more is better.
So a partial extra load resistor is usually needed, to bring them into the right regime..
Thank you very much.
bohrok2610. So the lt is lower noise. Thanks.
Joseph K. I knew about this but i completely forgot this... Thank you so much because i was going to build it without adding a load resistor. You saved me a pcb redesign, thanks.
