Any consensus on which has better perceptual audio performance (unity gain) in diff output stage of DAC? Seeking ultimate audio-band noise performance - open to other suggestions.
The AD797 has similar voltage noise and less current noise (for unequal impedances driving the positive and negative inputs), whether that matters depends on the impedance level.
Of those 3 (797, 1115, 1128) does anyone have an opinion on which is most perceptibly correct/accurate as a unity DAC output buffer?
Is there another IC opamp with "similar" noise specs that I should be considering? Perhaps the OPA1612?
