Can an LT1085 be used as a constant current LED driver? There is no mention of it in anywhere in the datasheet, but since this is an LM317 replacement can I use it the same way?
The old LM1085 has a current source (as a battery charger) in its application schematics so I don't see why not. I have had stability issues when using an LM317 as CCS so I'd pay attention to oscillations nevertheless.
Should D2 go before or after Rsense?
Doesn't R1 consume about 10mA from the regulator? Check the schematic in the first post.The LT1085 requires a minimum load current of 5mA to 10mA, so it may not be the best choice unless you want the LED's to glow quite brightly. A better choice for that application, you might try a simple discrete current source/sink, or try something like the Lm4041 for example.
Mike
D2, R1 and Pot are all useless in this schematic. C4 can be reduced to whatever is needed to keep the regulator stable.Can an LT1085 be used as a constant current LED driver? There is no mention of it in anywhere in the datasheet, but since this is an LM317 replacement can I use it the same way?View attachment 1156030
Unlikely, as R1 is shorted.Doesn't R1 consume about 10mA from the regulator? Check the schematic in the first post.
D2 may be unnecessary, but are you sure R1 and Pot(R2) are useless? They seem to limit the output voltage and can be useful for open-circuit/no-load voltage limiting.D2, R1 and Pot are all useless in this schematic. C4 can be reduced to whatever is needed to keep the regulator stable.
My comments apply to the schematic in the opening post, as you wrote: "Check the schematic in the first post."
In the circuit of post #3, R1 and R2 limit the output voltage, as is essential for a lead-acid battery charger. For a LED driver, you might as well let the output voltage increase to the input voltage minus the drop across the regulator when the load is disconnected.
- Design & Build
- Parts
- LT1085 constant current. will this work?
