LspCAD Questions...
Hi
Measuring FR of 2.5 way bass reflex, outside.
Now...
Calibration for 2 channel mode, manual says connect sound card line out to line in. But with a stereo line in I'm assuming you connect both channels (left and right) to the line out. That's what I've been doing. Correct?
Also, when measuring port response, I assume I should measure with both woofers in parallel since that's how the port output will occur under normal listening conditions?
Thanks.
Mos
