LR8N Spice model?
See attached. I got this model from a member of the LTspice users group at Groups.io. This model produces reasonable results in my simulations.
Edit: You will also need a compatible symbol file. I've also attached that here. The forum won't allow uploading files with the .asy extension so you will need to rename this file xreg3.asy before you can use it.
Thanks a lot, Ray!
Cheers.
