Lowering Fs by adding weight, Can't find the thread
Unless I'm dreaming I was reading a thread on adding weight on a sub woofer cone to lower the Fs. If I was dreaming how about adding weight or mass to the cone to lower Fs? I'm going to make the assumption that the added weight will not burden the voice coil. I was thinking about using Mortite ( rope insulation, sorta). Has anyone experimented? I fact, I think I saw this attempted on a project, in of all places Stereophile Can anyone help the lost? Have a great woofin day!
Thanks guys! more info please
Thanks Andrew, I saw one of the threads but all too soon the thread was turned into an obscure discourse on how great the manufactures were to sell expensive sub woofers lol. If I had the money I would buy a 18" Bag end and be done with it. Oh I was thinkingof a large glob of Mortite glued to the center dust cap. I don'tthink they make lead tape anymore 🙂
Not sure what you're looking for, but Ron E worked up this simple way to calculate how much it raises Qts, lowers efficiency:
mr = (Fs/Fs')^2
Qes' = Qes*mr^0.5
Qms' = Qms*mr^0.5
then: Qts' = Qes'*Qms'/(Qes'+Qms')
where:
mr = mass ratio
Fs' = new, lower Fs
New, lower effective efficiency:
n0’ = ~ [9.6352*10^-10*Fs’^3*Vas]/Qes’
SPLeff’ = ~ 112.018+10*log10[n0’]
GM
coating is one option is if the cone need stiffening
or use solid core copper thread to build a thick ring, and place/glue it where the cone and voice coil joins
it is indeed very tempting, but I have destroyed enough woofers to know it's no simple matter
one problem may be the tendency to use cheap woofers, with possibly very weak magnet gap, and no control
a woofer with light cone and BIG magnet, yet still with high Qts, are good reasons to be suspicious
and further
you also need good Xmax specs to make any sense doing this
which is often not the case
that said, this one worked out quite well ... but I was very lucky not to destroy it in the process 🙂
Thanks abcdmku, thanks all! great little calculator I find that by adding sixty grams I can lower the Fs from 21 to 18 Hz loosing only 1.5 Dbl. It will bring my Qtc Up to 7.5 but I can live with that as a slight deviation from my flat 0.7 as it gives me about 5hz improvement in extension, close to 15 hz plus or minus.
I hammered a piece of lead to form a very thin sheet.
Cut that sheet into strips and hand formed each to fit the cone shape just outside the dust cover.
Used double sided tape to glue the strips onto the cone.
I am sure I reported this years ago.
Since I've only done significant mass loading for 'sub' duty, I took the expedient of bonding driver cutout discs to the woofer with some loose fiberglass insulation in the cavity. Cheap, easy and much less chance of causing potentially destructive imbalance, with the downside of course that it's permanent.
For smaller drivers, I formed coils out of lead based solder to fit the 'well' of the dust cap/diaphragm junction.
GM
which method could depend on cone material, coating, etc
but can I ask why, and just curious ...
not producing good lows as is right now, or ... ?
