Lower optical output from Satellite reciever?
Several methods:
1. use digital volume control before converting to optical in source
2. use digital volume control after converting back to digital in receiver
3. use analogue volume control after DAC
Well, there is a 4th method:
4. develop and build an optical computer to directly process the optical data stream and modify the data
I need to have a lower output on my sattelite reciever,it has an optical output,
how do I do that?
check your receiver manual, often depending on the source, the volume gets bumped up do to various conversions formats. 5.1> stereo pcm
besides it might be good to keep a hot signal till the last stage of gain ( keeping S/N higher) .
Yes I know but it´s getting to much for the DSP I get dist in the bass.
And I cant lower it more in the dsp,If I play music from my PC I can lower the music so it plays fine,it´s just the Sattelite........
You are right,it is a bit of heavy EQ,I will try to lover the levels of the 3way arrangements.The dsp is the Nadja,the thing is it´s not just to lower it 10db on all channels you then must fine adjust the levels to...😱
