This may be a bit of a strange question, but I was wondering if anyone knew of any tube rectifiers that operate at lower voltages. I'm working on a variable DC (~0-15V, around 15W) power supply for a friend that's really adamant about having tubes on there. I have no issues with going with solid state regulators, or really any other part of the circuit, I'd just like to have some tubes in the circuit. I was also thinking maybe using a valve voltage regulator if I can't come up with some rectifiers.
Thanks all!
Thanks all!
Well, such things were done in the '30s when there was no other way... look up Tungar tubes, for example. But a 6V battery charger needed about 50V out of the transformer to work...
I do have a solid state Heathkit 0-60V power supply from the '60s that uses a VR tube as a voltage reference...
Well 15 watts at 15 volts is an amp so you would need a serious mercury rectifier. You'll still get 10-15 volts drop across each tube so that must be taken into account. Don't forget the filaments will probably draw around 10 amps each.
I suppose you could use some 6C33s as rectifiers but suffer from a higher voltage drop. Those draw some hefty heater current as well.
Theres always tungar rectifiers but you may have problems finding a reliable supply of them.
The most sensible option is using a low voltage pentode as the error amplifier for solid state pass devices.
Or a VR tube as a pilot light...
Actually, I had forgotten - there's a 1938 Thordarson booklet on my web page, which includes a 32V 3A power supply. It has 8 - '83 rectifiers, a 16 pound transformer and 11 pound choke and two 4 pound filament transformers (what do you expect from a transformer company...) http://www.audiophool.cjb.net/Misc/Thord_RSG_38.djvu
You could just use a silicon diode bridge and hook up a 5Y3's heater for looks. Cheating, I know, but your buddy's adamant about having tubes on this LV supply.
As stated before, your other choices are a hot, power-hungry mercury rectifier that's going to take days to heat up, or scarce tungar tubes that will be nigh-impossible to replace.
- Tubes / Valves
- Low voltage rectifiers?
