A new modle EL34 PP is under developping. It's a complicate design: input transformer, 12AT7 preamp, EL34 Push-pull, Optimus series OPT with cathode feedback. In order to find the benifits of OPT cathode feedback design we did a compare testing, the result is quite positive.
The amp under testing
THD measurement at 1W, 1KHz, 8Ohm
THD datas, THD1 is THD with OPT cathode feedback, THD2 is non OPT cathode feedback
The curve comparing
Close looking of the input transformer (black capacitor like cylinders)
Freqresponse from 10K to 100K, 3dB BW is up to 75kHz, awesome
Shcematic will be posted when the testing is finished.
The curve comparing
Yes, cathode feedback works well.
My current Tube Amp is EL34 (350V/60mA per tube) PP with screengrid (ultralinear) and cathode feedback and no overall negative feedback. ECC83 input/gain stage and 6SN7 "concertina" phasesplitter.
Sound is very different to common push-pull Amplifier, much more natural and relaxed.
Ciao T
Ciao T
A distortion reduction of far more than 12dB can not be accomplished with a 4ohm cathode feedback winding alone.
It doesn't look like he's making that claim, and the THD figures he gives looks like there's gNFB involved as well. gNFB with cathode NFB could get that 12db reduction in distortion.
So Siliconray,
You actaully said:
This doesn´t mean you only add GFB in one case.
Give us the correct figures about what happens with GNF applied in both cases. What you show doesn´t tell us anything about the cathode feedback effect.
Miles: The vendor made a claim and anyone could understand it was with and without GFB. Had to ask to get a correct answer.
Following my Breakup/Divorce I was left without any system (and money)...
I have been slowly building something up again, using was was available to me at low cost.
So my speakers are now only around 89dB/2.83V/1m and with around 6 Ohm Impedance. So an amplifier with more power is needed than a 300B can deliver and preferably cheaper.
My one was build on a "special sale" (scratch/dented/old series) chassis of the diyhifisupply Ella, that I got a good price on.
My circuit is brutally simple.
ECC83, both sections in parallel into a 150K Anode load (Kiwame), around 90V or so on the Anode, there is RC decoupling circuit there, 10uF Ansar MKP cap's, can't remember the series resistor value, or the cathode resistor (unbypassed).
This is DC coupled to a concertina splitter using 8K2 anode/cathode resistors (mint green silver leadout NOS Painton wirewounds) and either 6SN7 or 6N12P (kind of like an octal 5687 from russia, with love).
I use 0.1uF Silver/Mica caps as coupling cap's, bias comes from the diyhifisupply active bias module via 470K.
Output stage uses the 16 Ohm and 0 Taps to the cathodes and the 4 Ohm Tap to ground (so each tube has 4 Ohm feedback tap) and ultralinear feedback to the screengrids. Tubes run at 370V/60mA, so around 20W anode and 2W screengrid dissipation with a 5K anode-anode load. This is fairly far into class A FWIW, Class AB only on peaks.
Output Transformers and the rest of the Powersupply is original diyhifisupply Ella, CLC filtered per channel and with upgraded diodes and capacitors.
I measured around 35W for 3% THD, due to the circuit the Amp clips and distorts a little asymmetrical, not unlike a good SE Tube Amp.
It suits my speakers well and sounds quite good.
Ciao T
Do you want to share some more details of your amp. Would be appreciated. Why the shift from output triodes?
Ciao T
Thanks Thorsten
Thorsten
Thanks for the added information on your circuit. I remember Eisenson did a modification of the Dyna Stereo 70 back in the 70's using the same cathode feedback arrangement. The front end was similar to your's but with a pentode first tube to a triode concertina phase splitter. I think he retained the 7199 for these duties. Perhaps, an ECF80 would be a better choice. Nice to hear things are working out.
Thorsten
- Tubes / Valves
- Low THD of Opt Cathode feedback
