Low Sub Out signal
Newbie here...
I have a Martin Logan soundbar which I'm trying to add a subwoofer to using the subwoofer RCA output. I'm hoping to design and build a sub at a later time, but for now have an Onkyo powered unit.
The problem I'm having is that the subwoofer will only come out of standby with the soundbar volume up fairly high. And when the sub turns on, it's very quiet even with the gain maxed out. The sub does fine if plugged into my phone through a 3.5mm to RCA cable.
I'm assuming the soundbar's output signal is low.
Anyone have any ideas how I could increase the output?
Would a MiniDSP do it? I'd be interested in one for future use.
Appreciate any help!
David
Sent from my iPhone using Tapatalk
