I need sourcing for line transformer 10K/10K 40-15000 Hz +12DB level.
Any pointer for low cost but not cheap manufacturer ? *
thanks
*lower then well known compagny (jensen...)
thanks
These guys are pretty good value : https://item.taobao.com/item.htm?spm=a230r.1.14.24.658a679ez7OiO5&id=559758481077&ns=1&abbucket=2#detail
Got the name of british manufacturer on picture and wait for answer about tolerated levels. Thanks 😎Audio Transformers | RS Components
May be interesting, for some projects but can not retrieve valuable informations as automatique translation is approximative 😕These guys are pretty good value : 10K:10K??????????? ???????? ?????-???
Teasing spirit, Mark 😉 3,09V/600 ohms+12dB what? dBu, dBV, dBm, dBW?
The Triad TY-141P has been recommended on this forum: Triad 10k/10k input transformer TY-141P
http://www.farnell.com/datasheets/2279446.pdf
Not teasing at all, if you meant 12dBu, say 12dBu. dB by itself is not a measurement of a quantity its a ratio, use the wrong symbols and units and confusion ensues.
Would you buy unseen CAT5 cable of "length 15" ? Could be inches, metres, feet, you cannot tell.
In Europe, in the "good but cheaper than sowter" category, I'd consider:
- OEP, available at RS or Canford
- Carnhill, available at audiomaintenance.com (not much cheaper though)
- Edcor, available from Don Audio (quite a bit cheaper but the specs are often a bit vague)
Btw, it might be worth it to ask the question on the groupdiy forum. Quite a few transformers enthusiasts over there.
- Design & Build
- Parts
- Low cost transformer for line level ?
