1) syklab - 2 PCB, 2 ES9018K2M + oscillator + TPS regs + Crystek 950 (all pre-soldered)
2) quan - 1 PCB, 1 ES9018K2M (pre-soldered)
3) richard_pc - 1 PCB, 1 ES9018K2M (pre-soldered)
4) tubo - 1 PCB, 1 ES9018K2M (pre-soldered)
5) freeman - 2 PCB, 2 ES9018K2M (un-soldered)
6) mvsavage - 2 PCB, 2 ES9018K2M (pre-soldered)
7) danzup - 1 PCB, 1 ES9018K2M (un-soldered)
8) tvicol - 1 PCB, 1 ES9018K2M (un-soldered)
9) audiomaniac4u - 1 PCB, 1 ES9018K2M (pre-soldered)
10) atupi - 4pcb, 4 ES9018 4 TPS Regs, & 4 Crystek 950 - All soldered.
11) rredline - 1 PCB, 1 ES9018K2M + TPS regs (all pre-soldered)
12) DaveK - 1 or 2 kits
13)OverkillAudio - 4pcb, 4 ES9018 4 TPS Regs, & 4 Crystek 950 - All soldered.
14)Turbon - 2 PCB, 2 ES9018K2M + 2 oscillator + 2 TPS regs + 2 Crystek 950 (all pre-soldered)
15)eledanca - 1 PCB, 1 ES9018K2M (pre-soldered)
16)Ryssen - 1 PCB, 1 ES9018K2M + oscillator + TPS regs + Crystek 950 (all pre-soldered)
17)vuki - 1 PCB, 1 ES9018K2M (pre-soldered)
18)number9 - 1 PCB, 1 ES9018K2M+oscillator (pre-soldered)
19)badrisuper - 1 PCB, 1 ES9018K2M + oscillator + TPS regs + Crystek 950(pre-soldered)
20)dady - 1 PCB, 1 ES9018K2M + oscillator + TPS regs + Crystek 950 (all pre-soldered)
21)axeexa - 3 PCB, 3 ES9018K2M + 3 oscillator (pre-soldered)
22)linuxguru - 1 PCB, 1 ES9018K2M + oscillator (both pre-soldered)
Updated my order and unified with cristi289 order to have single shipping.
23) TheCoolestOne - 2 PCB, 2 ES9018K2M + 2 oscillator (both pre-soldered)
17)vuki - 1 PCB, 1 ES9018K2M + TPS regs (all pre-soldered)
23) TheCoolestOne - 2 PCB, 1 ES9018K2M + 2 oscillator (both pre-soldered)
Change in Quantity. IC now changed to 2.
11) rredline - 1 PCB, 1 ES9018K2M + oscillator + TPS regs (all pre-soldered)
Added an XG1000 oscillator.
'Hi syllable, the TPs reg are 17$ each or both? thanks.
I´d like to know this too.
Syllable maybe the resolution of pictures in post 212 is not great and i cant see the decoupling caps for audio opamps. Are they fitted somewhere in close vecinity of opamps ?
It is on the rear side so you cannot see it on that picture, it is very close indeed , https://drive.google.com/file/d/0B2ArnRLTrdN0WWhpVEhISGdXQXM/edit?usp=sharing
$17 for two pcs
1) syklab - 2 PCB, 2 ES9018K2M + oscillator + TPS regs + Crystek 950 (all pre-soldered) - PAID
7) danzup - 1 PCB, 1 ES9018K2M (un-soldered) - PAID
8) tvicol - 1 PCB, 1 ES9018K2M (un-soldered) - PAID
9) atupi - 4pcb, 4 ES9018 4 TPS Regs, & 4 Crystek 950 - All soldered - PAID
10) rredline - 1 PCB, 1 ES9018K2M + oscillator + TPS regs (all pre-soldered)
11) DaveK - 1 or 2 kits
12)OverkillAudio - 4pcb, 4 ES9018 4 TPS Regs, & 4 Crystek 950 - All soldered.
13)Turbon - 2 PCB, 2 ES9018K2M + 2 oscillator + 2 TPS regs + 2 Crystek 950 (all pre-soldered)
14)eledanca - 1 PCB, 1 ES9018K2M (pre-soldered)
15)Ryssen - 1 PCB, 1 ES9018K2M + oscillator + TPS regs + Crystek 950 (all pre-soldered) - PAID
16)vuki - 1 PCB, 1 ES9018K2M (pre-soldered)
17)number9 - 1 PCB, 1 ES9018K2M+oscillator (pre-soldered) - PAID
18)badrisuper - 1 PCB, 1 ES9018K2M + oscillator + TPS regs + Crystek 950(pre-soldered)
19)dady - 1 PCB, 1 ES9018K2M + oscillator + TPS regs + Crystek 950 (all pre-soldered)
20)axeexa - 3 PCB, 3 ES9018K2M + 3 oscillator (pre-soldered)
21)linuxguru - 1 PCB, 1 ES9018K2M + oscillator (both pre-soldered)
22) TheCoolestOne - 2 PCB, 2 ES9018K2M + 2 oscillator (both pre-soldered)
3) richard_pc - 1 PCB, 1 ES9018K2M + 1 Crystek 950 + TPS(ALL pre-soldered)
- Group Buys
- Low cost ES9018 DAC board GB
