I have a small problem with my BRAUN Turntable P4 and I think the problem is the OMRON G2V-234P 12 VDC Relay. I would like to change it but it is out of stock. This Relais switches of the sound output before the turntable starts playing. And every time the relais is clicking I heard a crackling sound out of the speakers.
Can anybody help me finding an replacement? Maybe the OMRON G5V-2-H1 12DC is an alternative?
Best regards from Germany,
Mirco
Mirco
I could not find the datasheet for OMRON G2V-234P but if the footprint, voltage/current rating and NC/NO contacts arrangement are the same then yes, it will fit. From the photos the relays look similar. There is another relay, Omron G6A-234P which looks similar too but I can't check dimensions.
Thanks for the very fast answer. Do you now the difference between the GV2-234P and the GV2N-234P.
For what stand the N?
Take the cover off and spray in some contact cleaner of sand the contacts with fine grit sandpaper.
Never sandpaper relay contacts, that is guaranteed to ruin them completely. Burnishing is
how to restore contacts.
- Design & Build
- Parts
- Looping for an replacement for OMRON G2V-234P 12 VDC Relay
