So I just to ask 1:1 models, this one Lundhal LL6404 is OK?
http://www.lundahl.se/pdfs/datash/6404.pdf
It would be good to read some of the Bill Whitlok transformer papers:
JENSEN TRANSFORMERS, INC. - APPLICATION PAPERS AND SCHEMATICS
Especially the audio transformer design chapter:
http://www.jensen-transformers.com/an/Audio Transformers Chapter.pdf
Thank you very much Kevin
Just came across this OEP transformer;
Technical Reference
I have used one of there other input transformers as a phase splitter on a power amp. Worked out reasonably well for a cheap component.
Shoog
Technical Reference
Shoog
The transformer is fro my friend that wants to convert the unbalanced output of the tube preamp CAT SL1-Signature +26dB of gain to balanced amp Pass X clone ALEPH-X - Pass Labs Clone Class-A amplifier PCB & schematic I have the idea to put the unbalanced to balanced transformer inside the Pass X clone. Still can be good the same advice?
TIA
Felipe
TIA
Felipe
- Tubes / Valves
- Looking for unbalanced to balanced transformer
