Relays seem like a necessary evil on power-amp outputs if you want to prevent on/off thumps and protect the speakers from destructive DC off-set. Right? Or not right?
The right type to use, in my mind, would seem to be normally-open-contacts type. Then they would start open and only close when the time-constant is through and no DC is sensed.
Then the quality of the contact's metal and plating seems to be essential. I have never seen any article reviewing relays brands or types, which I think would be more important than resistors, capacitors, diodes or even cables.
Does that metal & plating affect sound quality? Which is best?
Most do not specify what they use, and many of them look dangerously like nickel plated metal, probably copper.
Silver, gold-plate and silver cadmium-oxide are also popular on those that do specify the contacts. Which would be best or what sould we look for?
Carlos
Carlos
