Looking for the best MC-Amp (to my ears)!
I'm looking for the best phono amp (to my ears) to build and I realize that my taste/choice is not the same as you guys or perhaps it is? But to tell you the truth, I'v tryed these and still didn't find the one that makes me happy.
-ONO
-Pearl
-Spectral DMC 12
-Krell KRC and KPE
-Audio&Techniek Tube DIY MM stage with the SUN AUDIO SAT-1000 Transformer.
The one I'm using now is the PLINIUS M14 (from a friend) and to be honest I like the softness of the Pearl the most. But it does not reach the deep bass of the Plinius M14.
Frank, or an other forum member, can you help me?
I want to try the Tube MC Headamp Frank sheared with us, with the Plinius on MM. What do you think of this combination?
I have the Delphi MK III with the IKEDA tonearm and the Shelter 901 MC.
I hope It's not confusing to you guys.
Thank you very much.
Best regards,
Audiofanatic ;)
I have Audio Research SP-11 and I'll never part with it.. But while my SP-11 was on service, I could borrow SP-10 which is full valve amp, and I thought when, and if my SP-11 ever gives up on me, I'll buy SP-10. It's an old amp, but a true beauty.. Really great thing.. :)
An interesting question is whether the MC input in the Plinius is an add-on (like in Ono) or the gain of the entire phono is switchable. In the former case it will, indeed make sense to use a separate tube pre-pre.
The best types of phono preamps to my ears are variations of the Arthur Loesch circuit - 3 stages with split passive RIAA with separate PS for each stage. A very high quality transformer (amorphous or nickel) may be even better than an active MC input stage.
I am curious about the Allen Wright circuits - a different and interesting approach.
Does your assessment infer that the Pearl is superior to the Ono?
Ono vs Pearl
I'm Just saying that I like the sound to be tubeee!
The Ono sounds (again, to my ears,) to analitical
The Pearl sounds smoother more natural and yet not so tight in the lower region. Am I asking to much?
I want a combination of both world. Is this posible?
Best regards,
Audiofanatic ;)
P.S. the PLINIUS has no ad on stage, but can be done by soldering the tube input on the boards MM input.
In this case you may or may not experience an improvement using an additional tube stage as you are effectively complicating the signal path. As i am deeply suspicious of the concept of smoothness ( it seems to imply less resolution) i don't have further suggestions. Ime tubes bring 'smoothness' only when improperly applied.
regards
Best RIAA preamp
topology is three independet ams topology with split RIAA correction - I very agree with analog_sa :) . This topology : first amp - tau 1 + tau 2 - second amp - tau 3 - output amp is realy the best in listening test and very good with noise. As first amp you may to use AD 745 or any goog opamp with differential input maded with 2SK170 or 2SK147, certainly in this case for MM. For MC you must use "pre - pre " with AD 797 or to use good step up transformer - again I agree with analog_sa :smash: .
MC Section for Pearl
If you like the sound of the Pearl, why not add a gain stage to the input. Several others have done it with good results. The input stage of the Pearl is a great circuit to start with.
Mine is a pair of matched 2SK170BL, each sitting on a 22 ohm resistor. The pair is cascoded with a ZTX450.
Power comes off the Q5 second regulator of the Pearl. Through a 10 mH choke, 1000 ufd cap, then 700 ohm resitor to the ZTX450. The output is cap coupled with a 1 ufd stacked film and foil cap into the 47K input of the Pearl. The board fits right in the back of the case.
The sound is much better than it was running a pair of AN UK step up transformers. I think the MC stepups work better with tube phono than with solid state. I think it has to do with drive current. When you step up the voltage, the current gets stepped down. The resulting current cannot drive the combined gate capacitance of the 4 2SK170BL in the Pearl.
George
Paco, no me hagas eso!
fdegrove said:
And I'd second that one hundred percent.
In case Audiofanatic wants to go valves all the way, I'm most willing to help out....
Cheers,;)
Hi Frank,
I may go for a tube, but only in the Head amp. Not the full amp.
If you think you can convince me to go full tube, send me a private mail to convince me.
Best regards,
Audiofanatic ;)
Welterusten, late again!
OK, this has been bugging me all weekend long :) So how does one go about determining this? I have a Pearl, and I added input transformers to the chassis. I think mine are set up for 1:10 voltage gain (or current step-down). I tried finding datasheets for the 2SK170 transistors, and it looks like they have 30pF input capacitance? Could someone confirm that? The Pearl uses 4 of these in parallel, so that's 120pF. Which is pretty darn high, I think.
So how does one determine whether a specific cartridge, when its current has been stepped down a specific amount, is good enough to drive this capacitance? It boils down to a tradeoff between the reduced current drive with the transformer vs. the increased noise with an active head amp stage, right. Though if you can keep your noise below the surface noise of the vinyl then it doesn't matter...
120pF, 20KHz, 2.5mV, I can calculate the required slew rate from that. How do I find out how much current my cartridge is delivering?
And the Miller C is Cgk + (A+1)Cga, right? I'm not sure which one goes where for the FETs, but if it's the 30pF value that gets multiplied by the gain, then it gets even worse.
Sounds like a compelling argument to take out my transformers and try an active gain stage. Any suggestions? I'd prefer solid state, because I don't want to build a new power supply. Mayber I could try what Panelhead did.
And here I was, convinced that transformers were better for step-up duty than active stages. Damn you, Frank, blowing a hole through another one of my beliefs :)
diyAudio Senior Member
Joined 2002
Correct.
I fail to see the point but I think xformers have much improved over the passed 15 years...
I've known the Cotter as being pretty good, it's not perfect though.
Naturally at this early stage in the amplification stage, whatever sonic fingerprint is there, is going to be amplified throughout.
Come to think of it Audionote does the I/V conversion for their DACs in the exact same way we use for MC cartridges...
I use my MC Hammer design and that runs from a raw 30 something volts.
Cheers, ;)
OK, the point I was trying to make was that transformers may not always be the best solution for every step-up situation (as I once believed).
And I thought that was all that mattered, and that was reason enough to make transformers better than active stages, period. I hadn't considered the fact that the stepped-down current at the transformer's output might not be able to drive the input capacitance of the following stage.
Is that available anywhere? Or is it copyrighted?
Thanks for the help.
Saurav
Joined 2002
Something I neglected to mention is that when you know what effect the Miller capacitance is having you can take that into account into the calculations of your RIAA correction.
This eases design quite a bit but you have to know what you're doing with your devices, be that tubes, FETs or xformers.
The latter don't suffer from Miller capacitance but can have a roll off in the highs.
If you see the big picture you'll understand why xformers are the component of choice for so many designers...
I still have to hear one that's totally transparent but I'll be the first to admit that I just can't afford to listen to all offerings.
These dilemmas are exactly why I claim that a very good preamp is way harder to design than an amplifier.
If you know how hard it can be to design an excellent SE amp, think of a MC capable phono preamp as a series of cascaded SE amps having to deal with milivolts at the grid...
Not to mention noise, RIAA correction etc, etc...
And no, having an MC head amp or phono passing a few herz is NOT a good idea if you value your woofers.:att'n:
Cheers,;)
Konnichiwa,
Maybe you should try something like the Phonostage in my system now. You can check it out here:
http://www.arduman.com/aa/Sayfalar/thorsten/thorsten.htm
Scroll down towards the end....
Sayonara
MC Hammer!
Hi Frank,
I may try your designe eventualy. But first, your head amp and the Hiraga head amp! I'll let you know which one I like the most!
Thanks Frank and all other forum members, you'll hear from me within a few weeks.
I need to test the Tent XO2 first, probably by the end of next week.
Best regards,
Audiofanatic ;)
