Looking for the best 5" or 6" high sensitivity driver for an open baffle project.
..depends on the roll-off you net with a particular baffle (assuming you use one).
Basic target would be 2nd order LR (-6db) around 800 Hz. (..or a higher-order crossover: ideally an active solution with DSP correction.)
