Looking for LM3886 project (100W @8Ohm)
I am looking for a DIY project based on LM3886 which could deliever 100W @8 ohm per channel.
There are some projects out there (for example: https://electronics-diy.com/100w-lm3886-power-amplifier.php), but they refer to 4 Ohm and 100W.
Is it even possibe to use LM3886 in some configuration which would be able to deliever requested output?
Apologies if this was already discussed here. I checked, but didn't find it.
Thanks in advance!
Best regards,
Mario.
Have you seen any reports of a build of a build with that board?
First, thanks @adason for mentioning this board.
Now, I have one channel based on this board and it looks like indeed a promising project. Right now it is on my test bench and I have completed prelimminary meassurements. It has great frequency response and incredibly good square wave response.
Now, I'm testing its endurance on 200W 7.3 ohm dummy load. For time being I was able to run it at 125W constant 1KHz signal. I do really push it at the limits of thermal endurance.
Otherwise, the board is a real beauty, very well designed with wonderful layout. It is going to have from me a beauyiful chasis.
I intend to start a new thread devoted to this project. It will be fun. Very soon, perhaps this weekend.
Untill then, have a pleasant time.
Reactions: DaveFred
