Hello Guys,
I'm looking for a good DAC kit (or assembled).
I'm listening music in CD quality, but some frequency correction is also needed, so a 20bit or 24bit DAC would be fine.
What I already found:
I afraid, none of them are good quality designs.
I have seen some Abraxalito DACs here (I'm sure they are all well designed DACs), but all of them were 16bit only.
Do you have any recommendations for other valuable NOS DAC kits?
- Ladder DACs on ebay (for 65EUR or much more)
- Some PCM61, AD1865 based products, also on ebay (about 100 EUR)
I am just listening to Abbado 2 from Abraxalito as I type this. True, 16 bit only but it competes with my ESS Sabre 9018 Hifiduino with pcbs from Diyinhk. Abbado 2 is a superb little DAC.
The Abbado dac has some correction for high frequency rolloff common in NOS dacs built into it's output stage.
I do have a PCM58 DAC board that I've not posted a thread about, PCM58 chips are 18bits. But from what you're saying that's probably not enough.
If you're after NOS DACs then very few will use chips with 20bits or more. They'd be PCM63, PCM170X, AD1862 and that's about all of them.
No, having listened to PCM63 against PCM58, I decided it wasn't worth designing a PCM63 board. Especially given the rather large price differential between the two chips.
I'm getting parts together for a PCM58 NOS DAC. The datasheet shows 3.3uF decoupling caps of the +/-Vcc supplies and I assume that's TI's recommended minimum value but as I have a lot of Oscon 56uF caps could I use those instead?
Have you visited this ?Hello Guys,
https://www.diyaudio.com/community/threads/dac-ad1862-almost-tht-i2s-input-nos-r-2r.354078/
Probably a lot to read through but it is mostly summarized here :
https://electrodac.blogspot.com/p/dac-ad1862-almost-tht-i2s-input-nos-r.html
Yes you can use them, I currently run the PCM58 with 33u wet slug tantalum, and it sounds great.I'm getting parts together for a PCM58 NOS DAC. The datasheet shows 3.3uF decoupling caps of the +/-Vcc supplies and I assume that's TI's recommended minimum value but as I have a lot of Oscon 56uF caps could I use those instead?
- Digital Line Level
- Looking for high quality NOS DAC kit
