Hi everyone. I’m new here and this is my first post other than introducing myself. I’m having problems with an amp of mine and have decided to replace the 4 big caps. My amps is a PS Audio 200c and the caps are Mallory 15000uf 75vdc. I don’t have room for any longer than about 80mm by 68mm but could go narrower. The number on the Mallory cap is
CGS153U75W3C3PH
I’m looking for a screw cap that will be as close of a replacement as I can get that will fit. I know very little about this so I’m hoping I have given enough info and that someone might feel like helping me. Thanks in advance
CGS153U75W3C3PH
Ok. I’m going to do that first anyways but figured I would change those main caps anyways.
I had all the small ones changed a couple months ago
The form factor will be difficult to replace. Check with PS Audio first, in case they have back stock.
- Design & Build
- Parts
- Looking for hard to find replacement caps
