I have never seen schematics for EL32.
However, a circuit using 6V6 can be used if you multiply the cathode resistor by 1.95 as a ballpark value. It will require about twice the signal voltage from the driver stage for full output. Aim for an output transformer with 5kohm for single end and 8kohm for pushpull, i.e. the same as for 6V6/6BQ5/EL84.
