Hey folks,
My workshop and CNC are down and will be for quite some time. I have a project in progress and was wondering if someone could CNC a couple of plywood templates for me. I will provide all drawings and G-codes and am willing to pay whatever is necessary.
Thank you!
Thank you!
what size are the templates and where are you located? I've got a hobby level CNC, max job size 24x24 less clamping locations.
Thank you for your reply! 200x200x30mm (8x8x1.5 ish), so not big. I am in NC, but this size should not be problem to ship if that's ok.
my direct email is j_hofland@comcast.net if you don't find someone closer to help. In addition to the gcode file I'll need to know where you set the origin, What bit to use including feed rate and plunge rate and other stuff like using tabs, what are the material blank dimensions, and stuff like that
