Looking for big Ni lams
And after I post I see in their catalog that they don't do nickel in sizes larger than 125EI. You wanted 138 and 175EI.
Might still be worth a call though if you haven't tried them already. Maybe capitalize on that Christmas good will and all...:grouphug:
One can make big E lams out of doubled up U-I lams. And really big xfmrs are made exclusively with I lams.
(Which could be cut from a tape reel, plus a bolt hole puncher and hole alignment jig, and then you need to flatten them, maybe before cutting. Every other lam is overlapped in the stack to minimise gaps).
Just more stacking work.
You can also make E lam near equivalents by using two sets of cut cores. Might be interesting to use one M6 cut core and one Ni cut core.
Don
Don
I have a British output done like that. 4 C's arranged to give the same figure 8 magnetic path as E-I. Mixing the core material is just as easy to argue for as against IMO. I like the idea of homogeneous core assembly myself.
However, when making something *EXACTLY* like the originals one has little choice; include it, say it is left out, or commit fraud. I am preparing to do one of the first two since the third is already taken...🙂
cheers,
Douglas
Heyboer
Doug
I'm currently having Heyboer wind me a set of S265 transformers like the ones I heard at your house and hopefully they will be as good as the ones they did for you.. Those did sound incredible as the s271s would also I would imagine.
mikey
