Hi I am currently building a WMTMW system, originally it was a mtmw, Own compatment MTM, with seperate comparment for Lab12 as bass woofer crossover frequenecy is 200hz -300hz.
becasue I am going WMTMW and since the woofers would be sharing the same compartment, I was thinking to reduce the woofer size to around 8 to 10 inch but maintain the charactersitic of lab12 woofer.
So good suggestion would be appericate
8″ SB23MFCL45-8 / Polypropylene – Sbacoustics
I have the 4 Ohm version; these are great sub woofers but can be used as high as 800 Hz according to some people. If you get two per side, get the 8 Ohm version and wire in Parallel for 4 Ohms (per side).
http://sbacoustics.com/wp-content/uploads/2020/03/8in-SB23MFCL45-8.pdf
SB Acoustics SB23MFCL45-8, 8" Sub Woofer
from Madisound USA, including a review.
These can be used in smaller than normal closed boxes if need be.
(with my closed box and plate amp; I get bass as low as 14 Hz; of course; that is with bass management. The point is; for such a smaller diameter sub, these things can go REALLY deep and the X-max does it full justice)
