Looking for a transistor or a replacement. (2SK433) Marking (KE)
I'm trying to find a (2SK433) SMD transistor with the marking (KE) or a replacement.
  • 2sk433.pdf
    2sk433.pdf
I have searched everywhere.
It's a Korg Electribe SX ESX-1.
The volume is lower on one side (Left Side (F201 on Schematic)) and I found the 2sk433 from the Schematic I posted above .
Its on the amp part so I thought I could get help here.
Q: Have you tried performing a parameter search on octopart, digikey or mouser to see if anything came up?
A: I found the part but I don't know how to use Octopart website.
Q. What is the control voltage when the output is enabled and when it's muted?
A: I have not tested it. Do you think I could get information from the working channel (Right Side (F202 on Schematic))?
it all depends on the voltage difference between the tube grid bias and the fet supply. still I do not expect that larger than 20V. more the idss rating of the original fet is important, and the trim can set the same required tail current.
