I need to replace an old alps pot since its gone open circuit.
The markings on it are 100kBx2. 100k ohm, double gang, B taper.
Its a 17mm body with a plain 30mm long shaft.
The closest I could find would be a bourns PDB182-K230P-104A. However I can't find stock of it anywhere...
I tried Digikey, mouser, element 14 and RS components.
Does anyone have any suggestions of where else to look?
B means its a linear pot. These must be available 'anywhere'
PC2G16ECO100KA - OMEG - POT, DUAL GANG, LIN, 100K | CPC UK
And tags, not pins but shouldn't be a problem,
27ESA104MMF50NF - TE CONNECTIVITY / CITEC - POTENTIOMETER, D/GANG LIN 100K | CPC UK
The shaft length is shorter on this, but looks like a drop in otherwise.
DUAL 100K POTENTIOMETER | All Electronics Corp.
MI
MI
