Looking for a preamp kit
I'm on the hunt for a preamp kit.
My needs are simple: I need a few inputs, volume control for the main output, and a fixed-volume "record out". I'll need a phono pre, but if it's not incorporated in the the preamp I can always use a standalone unit like the Muffsy.
Tube, solid state, or passive. Doesn't really matter, but I think I'd prefer solid state or passive.
It's OK if it isn't sold as a kit with parts: PCB/Gerbers + BOM will do the trick.
So far I've found two that seem to fit the bill:
The Akitika PR102 has everything I need, but I'm not crazy about the looks. Looks are easy enough to change, however.
The Glasshouse Passive Preamp No.1 also has everything I need, and I like the look, but it seems to be possible only to build it with a stepped volume attenuator, and I much prefer a potentiometer volume control, as stepped attenuators never give me the precision volume levels I want. I've written them to ask if it can be built with a pot, but they've not replied.
So I'm poking around for other options. Any recommendations?
