I'd like something that can hold half dozen rolls of wire, and grip the ends so I can easily grab and pull however much I want, like a packing tape dispenser. I also worry about the spools coming undone. Most of what I see is just a rod that goes through the spools, with no particular guide or control for the wire feed. Am I imagining a product that doesn't really exist?
Dispensers are common for very large wire spools, but not so much for small ones.
You could make something yourself, to go with a standard wire rack.
Some of the few for smaller wires: harbor freight 400 ft wire storehouse 61527
https://www.amazon.com/Fermerry-Stranded-Flexible-Silicone-Electrical/dp/B089CW7YSR
@SoaDMTGguy , it weems to me the feature you're looking for is a mechanical one-way "valve". It allows the wire to be pulled out, but prevents it from being rolled back onto the spool.
no?
Kind regards,
Drew
no?
Kind regards,
Drew
https://www.wurthusa.com/Shop-Suppl...Dispenser-For-Organizational-System/p/0956109
This seems pretty close. I wish they had a better picture. Or a description.
The problem I’ve found with putting them all one next to another on a common rod is that when the spool rims touch, as you pull from one, it tends to turn the ones next to it as well, causing them to unspool or at least loosen. Something with fixed dividers between each would prevent that. All that said, I haven’t gotten ambitious enough to build such a holder so tend to keep the spools on a box sequestered by gauge/type, and put them back after getting what I need. Small gauge with thin insulation I secure by doubling back and looping through the last turn; thicker I twist a rubber band around the end then stretch the big loop around the spool.
-Pat
-Pat
I like the look of that Wurth unit but replacing individual spools on a common axle with some manor of clutch involved may be a minor pain.
Turn each spool 90°, with rails along each end, a small bolt for each individual axle, a pair of fender washers and a cork (or other) disk to act as a clutch would be easy in that regard. I'm imaging slots to receive the axle to avoid threading it all together in place.
- Design & Build
- Equipment & Tools
- Looking for a good wire dispenser
