Check out Edcor for reasonable priced options. Anything suitable for a 6L6 ought to be OK, alternately work out the desired load line and configuration and have them build something suitable.
Should also mention Electra-Print, if you are not exactly sure what you want Jack can probably tell you. (Also very reasonable)
I've used and recommend both manufacturers. (No association otherwise)
decent pair of 807 output transformers
Try Heyboer TX's. Talk to them, they can wind you what you need.
Heyboer Transformer - Top
No affiliation, just satisfaction.
