looking for a cabinet for the CHN70
Hi All, here is suggestion that is as simple as can be to build. It is a variation of our Händel series Händel family, but one that we are happy to give away.
You could safely make 10er at the top and them damp a bit more. Gives a very nice tight bass.
Have fun, Kurt
FWIW, this weekend I finally got around to installing a pair of these in FH3 (with removable baffle to allow for swapping a range of new drivers) . These little puppies have no trouble with lower mid bass - but would certainly benefit from woofer support for the bottom octave and half (well, maybe 2 1/2 if you consider that only getting to 20Hz is not quite deep enough)
Hi Gaston. I find the CHN-70 entirely satisfying, it is my daily listener in my office together with a special BIB like horn with the Alpair 6. When listening to Internet radio, MP3s or older 60'ies recordings, I switch to the CHN-70 as the Alpair 6 reveals to much of the poor recording quality. CHN-70 smooth things out a bit, not a puritan driver like the other paper drivers, but very nice, and much better than the Monacors or Founteks, you can find. If you want a bigger box a classic TQWT will do fine and go deeper.
Cheers Kurt
to repeat post#7 above - CHN70 works very well in the FH3 - if you have the floorspace
Nice to hear that :D
CHN70s are getting very good reviews, and considering it's price they are really worth.
The FH3 has turned out to be a very flexible enclosure, although difficult to build (angle cuts) it's looks are stunning! :cool:
I have them with a pair of A7
A big thank you to Scott, Dave and you for giving us this wonderful enclosure, and testing them with so many drivers to suit every taste/budget. :worship:
If you are looking for an ultimately easy build, here is one for you, we call it the Charlie Parker: http://goo.gl/XDN43X.
It consist of 2 pieces of drain pipe 110 mm in diameter, a t-piece in the middle and a plug at the top. The foot is homemade. It took my under 2 hours to put them together. The characteristics match the CHN-70 quite well, ideally we should have had a slightly bigger diameter. Very nice imaging. If you want to see the whole build process take a look here Picasa Web Albums - Kurt Nielsen - CharlieParker
-- Kurt
how is the high frequency end of the chn70?
Cheers Kurt
Hi, fellow MarkAudio enjoying listeners!
I am a bit reluctant to buy a set (or two?) of CHN70's as I am used to chr70.3 now. Is the high frequency part for the chn much less loud compared to the chr?
Thanks, August
