I need a potentiometer as replacement part. It works as level adjust in this Jeep CD Radio:
Jeep CD 343 CD Stereo Radiorecorder Komplett UND Optisch GUT Erhalten Bastler | eBay
It looks similar to that one from the follow pics, but with other shaft version:
19mm ROTARY POTENTIOMETER STEREO 50K-A 6-PIN PCB Rotary Potentiometers s1798s
Invalid Request
EVJ-C20F02A14 - PANASONIC - POTENTIOMETER, 10KOHM, 50mW, 20 | Farnell Deutschland
Naturally the outline of a usual stereo potentiometer is like follow:
http://www.retroamplis.com/WebRoot/...0A8/28BC/509E/Alpha_16_stereo_PCB_knurled.jpg
What is the colloquial expression for this kind of potentiometer (best keyword for google)?
http://www.soundservice.gr/e-shop/images/s1798s-12s.jpg
Invalid Request
Dual-gang Axial potentiometer, though Google hasn't yet caught on 😀
https://www.buerklin.com/en/catalog/Film-potentiometers-type-ALPS-RK11K-RK14K-E107450.html
Thank you for this advice.
The website from Alps provides this overview from RK14 series:
RK14K Series - Products Line
The closest versions from that I need are this:
http://www.alps.com/prod/info/E/HTML/Potentiometer/RotaryPotentiometers/RK14K12/RK14K12D0A18.html
http://www.alps.com/prod/info/E/HTML/Potentiometer/RotaryPotentiometers/RK14K12/RK14K12C0A0T.html
http://www.alps.com/prod/info/E/HTML/Potentiometer/RotaryPotentiometers/RK14K12/RK14K1240D04.html
unfortunately the length of the shaft is too short and too thick. I need diameter of 4mm instead of 6mm and a length of approx. 60mm.
Extenders don't work for you? You can use some scrap aluminum or wood to shape one...
I also advocate jury-rigging, where you use a regular pot and wire in the physical leads to the board using small lengths of jumper wire.
Space is too low therefore. additional there is an additional part mounted on the genuine shaft to confirm a clicker for switch on/off.
The model of the radio cd recorder is "jeep CD343".
I also think so. But which model use the same potentiometer version than the wanted - this is for me the most important question cause its unsusual version.Look for old/junk car stereos. You might find one.
Gajanan Phadte
Here the pics from the first URL from post #1 (to save them from decay/delete):
Yes. Best way it is, to find out other good available models with the same part. In this case I discover the dvd player model "Supervision 1200/85515" - have a look to the pictures. The showed version is for horizontal mounting. There are also versions for vertical mounting - e. g. in the Technics integrated amplifier SU-700 (image No 5 and 6)Look for old/junk car stereos. You might find one.
Gajanan Phadte
- Design & Build
- Parts
- Looking for 1 Pole Stereo potentiometer
