Everybody is good. Give the circuit diagram offering UL41 PP to me? Thank you very much.
R RCA245 Member 2005-04-10 7:39 pm Taipei 2005-05-10 7:35 pm #1 2005-05-10 7:35 pm #1 Everybody is good. Give the circuit diagram offering UL41 PP to me? Thank you very much. ••• More options Share
G gingertube Member 2004-10-11 7:42 am Adelaide South Oz 2005-05-11 5:39 am #2 2005-05-11 5:39 am #2 Look here for UL-41 Datasheet. The sheet has the information required for running 2 UL-41 in Class AB1 Push Pull. http://www.mif.pg.gda.pl/homepages/frank/sheets/030/u/UL41.pdf Hope this is some help, Cheers, Ian ••• More options Share
R RCA245 Member 2005-04-10 7:39 pm Taipei 2005-05-11 7:32 am #3 2005-05-11 7:32 am #3 Hi Ian, Thank the information that you offer. But I need circuit diagram. Because I am a beginner, will not design. THANKS. ••• More options Share
