Look for EL33 PP structure circuit
leadbelly said:
he really means EL33
Oops... not a tube i've heard of before... same circuit would work, but with adjustment of cathode R & an OPT with a lot more pimary -- looks much more like an EL84 then an EL34.... i'm using the above as a basis for a PP amp with EL84s leveraged off a pair of Dynaco SCA35s
dave
http://www2u.biglobe.ne.jp/~tossie/6V6-E.html
Thank you very much for the help of dave and leadbelly. 😀
http://artifactaudio.com/EL33specs.JPG
Ask dave again. Please tell me?
In the webpage "Two valves in Push-Pull".
Va=250V
Vg2=250V
Rk=140 ohm
Vin=13V
I can change the circuit of this 6V6 below its Va , Vg2, Rk and Vin, make it become circuit of EL33 PP?
Make having 296V in the picture into 250V,
Rk =250 ohm is changed into 140 ohm,
Make with 18V into 13V.
Can become EL33 PP in this way?
Thanks.😀
Re: http://www2u.biglobe.ne.jp/~tossie/6V6-E.html
pretty much... i'd put a CCS on the cathodes of the long tail pair and just use it as the phase splitter and gain stage (you might need a higher gain tube) -- this would eliminate the 1st 2 stages.
dave
Re: Re: http://www2u.biglobe.ne.jp/~tossie/6V6-E.html
dave [/B]
Dave, thanks your replying.
Sorry ! What is CCS? :dead:
If use this circuit below, OK?
http://www.tubecity.com.tw/images/cir3.gif
Or change the 1st 2 stages (first 6sn7) into EF86 etc . high gain tube?
But change into high gain tube, so become bad linearly?
Thanks.
Re: Re: Re: http://www2u.biglobe.ne.jp/~tossie/6V6-E.html
Constant Current Source
That is the same circuit, different ouput tubes and details ...
EF86 straffed in triode is excellent.
something like this is what i suggest (note similarities to PP1C above)
dave
Re: Re: Re: Re: http://www2u.biglobe.ne.jp/~tossie/6V6-E.html
dave
Hi Dave.
http://www.diyaudio.com/forums/attachment.php?s=&postid=619316&stamp=1113444357
Only is it all right to need two stage? ?
Could you tell me that needs one stage foremost?
