Long Distance Interconnects
I have a situation where I have approximately 50 feet between my tube preamp and tube amplifiers. Bruce Rozenblit of Transcendant Sound tells me that even with his very low output impedance Grounded Grid Preamp, I will be rolled off 6 dB at 20 KHz by the time that I get to the amps.
My questions are:
Does anyone remember the formula for that rolloff?
Is there a way around moving the amps to my already overcrowded equipment shelves?
Do I need to equalize the cable runs (35' vs 50') to the amps to at least equalize the rollof between channels?
I've thought of going to transformers to run balanced low impedance lines. We routinely run hundreds of feet of pro line level cable in radio. For critical home use however, I'd rather avoid iron and / or silicon in the audio path.
Any help would be appreciated, especially that formula.
Bob
Long cable roll-off
Hi
In the drawing below, consider the generator
on the left as the actual output of your pre-amp
while the resistor next to it is the output impedance of the same.
on the right is the input impedance op the
power-amp. In between the cable of wich,
most likely, only its capacity is relevant here
as its resistance will be probably 100000x
smaller than the input impedance.
Also we may assume that the input impedance of the power-amplifier will be much higher
than the output impedance of the pre-amp.
The roll-off will be caused mainly by the capacitance of the cable.
-3dB will occure where the reactance of that capacitor (cable) equals the output impedance of your pre-amp.
So determine the output impedance of your pre-amp.
-connect a signal generator to the
input of the preamp with any signal that
will give fair output f.e. 1 Volt reading on
a voltmeter at 1kHz. at the output of the pre.
-Connect a variable resistor ( potentiometer)
to the output and reduce its value untill
the voltage drops to 0.5 Volt.
-Measure the resistance of the pot wich
now represents the output-impedance.
to the output,
CableCapacity from mnf. specs
Reactance is Xc
..............1
Xc = -----------
........2 (pi) f c
(ignore the dots in the formular)
Andre
Forgot the schematic :xeye:
Thanks to andre for the Formula!
The suggestion of a low impedance driver makes sense only to a point. Burces preamp already is only 200 Ohms. Much lower than that is silicon territory. I'm thinking that I have to find a place for the power amps near the preamp and some large gauge speaker cables.
Bob
