I just got the best computer speaker system ever designed, the Logitech Z-680.
The sound is amazing, and I don't think I have ever heard as much bass from any 8-inch sub before.
I was wondering, has anybody opened up one of these and looked at what chips it uses?
I am sure it would use chip amps, but which ones?
Thanks, Mike
Thanks, Mike
Well, I don't want to risk opening up a $400 speaker that I just got a month ago 🙁
I almost think it could be 5x 3875 to get 50W/ch and a lm4651/52 combo for the 200W sub?
-Mike
-Mike
There are 7 tda7293 in there, 2 are bridged for the sub.
How I know ? Well, my friend owns a computershop, and I owned a screwdriver 😉
OK, thanks!
But one thing, if thats true, how come the center channel is 59W, and the other channels are only 53W?
-Mike
-Mike
Yeah, I tore one of the z-560 subs apart this summer after a friend of mine had to return his system (logitech just makes you cut off the control box and send that to them). This one had 6 TDA7293 chips in it, I'm assuming from the one of the previous posts that 2 are bridged for the sub again. Oh, all the electrolytic caps on the board are "chang" brand, anyone know if these are any good?
I thought those figures where the powerhandling of the satellites.
Take a look at this:
http://www.dansdata.com/speakersets.htm
Actually, my system is defective, and has to be sent back to them. The problem is that when the left heatsink (i assume the sub amp, since it gets hotter than the other heatsink) gets warm, it starts rattling loudly. The rattle is very annoying. Plus, it only takes about 15 minutes at less than half volume on the speakers and half volume on the pc to start rattling.
By "Cut off the control box and send it to them", does that mean I am going to have to just remove the amp and send it to them, meaning I save on shipping costs and get to keep a nice sub speaker/box? Or are you talking about something different?
Thanks, Mike
Thanks, Mike
for my friend, "cut off the control box and send it to them" meant cutting the cord coming out of the back of the volume/bass/treble/m3d control unit and sending that unit to them. I think the philosophy behind that is so you can't actually use the system any more...you're just left with all the satelites and the sub to gather dust...
soundNERD said:OK, thanks!
-Mike
Limited by the speaker power ratings ?
You know, for 400$ you can build pretty good DIY speakers and use your lm3386 projects instead of buying "computer" speakers. Or buy reference grade headphones and save the other stuff for the HT setup.
Just my point of view though...
Anders
Anders
toque_101 said:for my friend, "cut off the control box and send it to them" meant cutting the cord coming out of the back of the volume/bass/treble/m3d control unit and sending that unit to them. I think the philosophy behind that is so you can't actually use the system any more...you're just left with all the satelites and the sub to gather dust...
haha - not a problem for us! we could just rewire the amps inputs.
I wonder if they will only make us send them the control unit? It is removable since it connects with a monitor cable.
Well, too late now. I would have just brought it back to best buy, got my money back and bought it again. Buy Best buy already discontinued this item!!
I hate Best buy now; they do this all the time with new stuff, especially if its too high end for them (basically anything), they decide not to carry it.
Anyway, I think these were $200, plus a $50 free gift card by mail and however many reward zone points you get, so they were a good deal.
One more thing I was wondering, are the TDA chips used high end ones? I would think so, but when the manual hinted that they have no SC protection, by saying that shorted speaker wires may damage the unit, I wondered if they really are that good of a chip.
Thanks, Mike
Thanks guys!!
OK, I called Logitech and ordered my new set.
I'm going to mail the control box tomarrow (friday)
Since I have some good speakers sitting around, so I took the center and rear speakers and used them for my surround system (before, i only had B&W fronts and a infinity sub). Now, I have a full surround sound system.
Now, with the subwoofer, I would like to figure out how to open it. I removed the screws, and there were a bunch of wires glued to the wood case. Which ones should I carefully pull off of the wood, and which 2 are for the sub.
What I want to do by that is hopefully find what rattles. Once I find that, I would like to be able to use the sub and the 2 remaining speakers for my laptop in my room (a 2.1 setup). How should I rig the amps to allow a standard Left/Right signal to be inputted (or, what pins are the audio input on the control unit? Then, I could connect my PC output to a pot for volume control and to the correct pins on the back of it to allow it to work again.
How should I go about it, and is this even possible?
If I can't get rid of the rattle, I'll just build a new amp for it.
Thanks everybody!
-Mike
Thanks everybody!
-Mike
Joined 2002
These logitech speakers are nice.. i have a pair of tb's im going to be using for this exact project and a subwoofer Donated from Planet10 in-trade of a pair of horn's im going to build a 4 channel amplifier using the lm chips 2 chips per speaker one for tweeter and one for driver.. and a active xover and a separate amplifier. right now im using the tb's in Juice cans and well moving around the room in certain spots proves these little tb's can produce allot and crisp and clean bass.. although i like a little more just for the extra punch. so soon ill be playing with fiberglass and new enclosures
J
J
I used to have this speaker set, for the money it will compete with sub/sat systems from normal hifi companies, costing over twice the price.
For a small/medium living room it is ideal as a surround sound setup.
save your expensive speakers for 2 channel setup!
soundNERD said:I just got the best computer speaker system ever designed, the Logitech Z-680.
Monsoon would be giving these a decided run for best ever. The computer store i work (part-time) at recently got a good portion of the last units available and at $50 CAD/pr the MH502s have got to be the best bargin ever for computer speakers (actually they are MH-350s -- 502s with cloth grills)
AndersZ said:You know, for 400$ you can build pretty good DIY speakers and use your lm3386 projects instead of buying "computer" speakers.
The LogiTechd use a Tangband 3" -- 5 of those would run you $50.
dave
Joined 2002
and since i already have 2 of them and a set of tweeters i'm going to use them and implement the lm chip's to run them. : O ) should sound good.. S far these little TB's Sound SWEET.. for 3" drivers i'm defiantly impressed.. : O)
Thanks guys,
but does anybody know the pinout of the control unit?
Also, I guess i should have said "in my opinion the 680s are the best pc speakers ever designed"
But if I'm right, those Monsoon flat speakers were at circuit city for a few months last year. If I remember right, they didn't sound good at all. but this is all my opinion.
-Mike
-Mike
- Chip Amps
- Logitech Z-680
